AD815,pdf datasheet (Different
消耗积分:3 | 格式:rar | 大小:471 | 2009-09-02
分享资料个
The AD815 consists of two high speed amplifiers capable of
supplying a minimum of 500 mA. They are typically configured
as a differential driver enabling an output signal of 40 V p-p on
±15 V supplies. This can be increased further with the use of a
coupling transformer with a greater than 1:1 turns ratio. The
low harmonic distortion of –66 dB @ 1 MHz into 200 Ω
评论(0)
发评论
下载排行榜
