ADD8504/ADD8505/ADD8506,pdf da
消耗积分:3 | 格式:rar | 大小:256 | 2009-09-02
hxjq
分享资料个
The ADD8504, ADD8505, and ADD8506 are 4-, 5-, and 6-channel LCD gamma reference buffers designed to drive column driver gamma inputs in line inversion panels. Each buffer channel has an A/B input to select between two gamma voltage curves. These buffer channels drive the resistor ladders of LCD column drivers for gamma correction. The ADD8504/ ADD8505/ADD8506 outputs have high slew rates and output drives that increase the stability of the reference ladder resulting in optimal gray scale and visual performance.
评论(0)
发评论
下载排行榜
