The MAX3540 complete single-conversion television tuner is designed for use in analog/digital terrestrial appli- cations and digital set-top boxes. This television tuner draws only 760mW of power from a +3.3V supply voltage. The MAX3540 is designed to convert NTSC or ATSC sig- nals in the 54MHz to 860MHz band to a 44MHz interme- diate frequency (IF). The MAX3540 includes a variable-gain low-noise ampli- fier (LNA), multiband tracking filters, a harmonic-rejec- tion mixer, a low-noise IF amplifier, an IF power detector, and a variable-gain IF amplifier. The MAX3540 also includes fully monolithic VCOs and tank circuits as well as a complete frequency synthesizer. This highly inte- grated design allows for low-power tuner-on-board applications without the cost and power-dissipation issues of dual-conversion tuner solutions. The MAX3540 is specified for operation in the 0°C to +85°C temperature range and is available in a leadless 48-pin flip-chip (fcLGA) package. Applications Televisions Analog/Digital Terrestrial Receivers Digital Set-Top Boxes Cable Modems VOIP Gateways
