MAX16818 pdf datasheet
消耗积分:5 | 格式:rar | 大小:666 | 2008-06-30
分享资料个
The MAX16818 pulse-width modulation (PWM) LED dri-
ver controller provides high-output-current capability in
a compact package with a minimum number of external
components. The MAX16818 is suitable for use in syn-
chronous and nonsynchronous step-down (buck)
topologies, as well as in boost, buck-boost, SEPIC, and
Cuk LED drivers. The MAX16818 is the first LED driver
controller that enables Maxim’s patent-pending technol-
ogy for fast LED current transients of up to 20A/μs and
30kHz dimming frequency.
This device utilizes average-current-mode control that
enables optimal use of MOSFETs with optimal charge
and on-resistance characteristics. This results in the
minimized need for external heatsinking even when
delivering up to 30A of LED current. True differential
sensing enables accurate control of the LED current. A
wide dimming range is easily implemented to accom-
modate an external PWM signal. An internal regulator
enables operation over a wide input voltage range:
4.75V to 5.5V or 7V to 28V and above with a simple
external biasing device. The wide switching frequency
range, up to 1.5MHz, allows for the use of small induc-
tors and capacitors.
The MAX16818 features a clock output with 180° phase
delay to control a second out-of-phase LED driver to
reduce input and output filter capacitors size or to mini-
mize ripple currents. The MAX16818 offers programma-
ble hiccup, overvoltage, and overtemperature protection.
The MAX16818ETI+ is rated for the extended tempera-
ture range (-40°C to +85°C) and the MAX16818ATI+ is
rated for the automotive temperature range (-40°C to
+125°C). This LED driver controller is available in a
lead-free, 0.8mm high, 5mm x 5mm 28-pin TQFN pack-
age with exposed paddle
评论(0)
发评论
下载排行榜
