ADA4410-6,pdf datasheet (Frequ
消耗积分:2 | 格式:rar | 大小:334 | 2009-09-04
分享资料个
The ADA4410-6 is a comprehensive integrated filtering solution that is carefully designed to give designers the flexibility to easily filter and drive many types of video signals, including high definition video. In the RGB/component channels, the cutoff frequencies of the sixth-order filters can be selected by two logic pins to obtain four filter combinations that are tuned for RGB, high definition, and standard definition video. Cutoff frequencies range from 9 MHz to 36 MHz.
评论(0)
发评论
下载排行榜
