ADA4302-4,pdf datasheet (Activ
消耗积分:3 | 格式:rar | 大小:555 | 2009-09-04
哈哈哈
分享资料个
The ADA4302-4 is used as an active element in applications where a lossless signal split is required. Typical applications include multituner cable set-top boxes, cable splitter modules, multituner televisions, and home gateways where traditional solutions have consisted of discrete passive splitters followed by separate fixed gain amplifiers. The ADA4302-4 is a low cost alternative solution that simplifies designs and improves system performance by integrating a signal splitter element and gain element into a single IC solution.
评论(0)
发评论
下载排行榜
