ADUC834,pdf datasheet (ADCs wi
消耗积分:5 | 格式:rar | 大小:667 | 2009-09-04
分享资料个
The ADuC834 is a complete smart transducer front end,
integrating two high resolution - ADCs, an 8-bit MCU, and
program/data Flash/EE memory on a single chip.
The two independent ADCs (primary and auxiliary) include a
temperature sensor and a PGA (allowing direct measurement of
low level signals). The ADCs with on-chip digital filtering and
programmable output data rates are intended for the measurement
of wide dynamic range, low frequency signals, such as those in
weigh scale, strain-gage, pressure transducer, or temperature
measurement applications.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
