MAX15026 pdf
消耗积分:3 | 格式:rar | 大小:666 | 2008-06-30
分享资料个
The MAX15026 synchronous step-down controller oper-
ates from a 4.5V to 28V input voltage range and gener-
ates an adjustable output voltage from 85% of the input
voltage down to 0.6V while supporting loads up to 25A.
The device allows monotonic startup into a prebiased
bus without discharging the output and features adap-
tive internal digital soft-start.
The MAX15026 offers the ability to adjust the switching
frequency from 200kHz to 2MHz with an external resis-
tor. The MAX15026’s adaptive synchronous rectification
eliminates the need for an external freewheeling
Schottky diode. The device also utilizes the external
low-side MOSFET’s on-resistance as a current-sense
element, eliminating the need for a current-sense resis-
tor. This protects the DC-DC components from damage
during output overloaded conditions or output short-
circuit faults without requiring a current-sense resistor.
Hiccup-mode current limit reduces power dissipation
during short-circuit conditions. The MAX15026 includes
a power-good output and an enable input with precise
turn-on/turn-off threshold, which can be used for input
supply monitoring and for power sequencing.
Additional protection features include sink-mode cur-
rent limit and thermal shutdown.
Sink-mode current limit prevents reverse inductor cur-
rent from reaching dangerous levels when the device is
sinking current from the output.
The MAX15026 is available in a space-saving and ther-
mally enhanced 3mm x 3mm, 14-pin TDFN-EP pack-
age. The MAX15026 operates over the -40°C to +85°C
temperature range.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
