MAX16836.pdf
消耗积分:5 | 格式:rar | 大小:787 | 2008-06-30
分享资料个
The MAX16836 current regulator operates from a 6.5V
to 40V input-voltage range and delivers up to a total of
350mA to one or more strings of high-brightness LEDs
(HB LEDs). The output current of the MAX16836 is
adjusted by using an external current-sense resistor in
series with the LEDs. A dimming input allows wide-
range “pulsed” PWM operation. Wave-shaping circuitry
reduces EMI. The differential current-sense input
increases noise immunity. The MAX16836 is well suited
for applications requiring a high-voltage input and is
able to withstand automotive load-dump events up to
40V. An on-board pass element minimizes external
components while providing ±3.5% output-current
accuracy. Additional features include a 5V regulated
output and short-circuit and thermal protection.
The MAX16836 is available in a thermally enhanced,
5mm x 5mm, 16-pin TQFN package and is specified
over the automotive -40°C to +125°C temperature range.
Applications
Automotive Interior: Map, Courtesy, and Cluster
Lighting
Automotive Exterior: Tail Lights and CHMSL
Emergency Vehicle Warning Lights
Navigation and Marine Indicators
General Lighting
Signage, Gasoline Canopies, Beacons
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
