异步升压转换器中的肖特基二极管的选择_英版
消耗积分:1 | 格式:rar | 大小:377 KB | 2016-12-05
zjxhit
分享资料个
Asynchronous boost converters require a Schottky diode as the rectifying element due to the diode's low forward voltage and fast turn-on time. Because of these characteristics asynchronous boost converters can have as good as, or better efficiency, than synchronous boost converters. This is especially true when the boost conversion ratios (VOUT/VIN) are high, and the Schottky diode conduction time is low. Figure 1 shows a typical boost converter used in an LCD backlight application. Circuits like these are good examples of how picking the right diode is important in achieving maximum efficiency and performance.
评论(0)
发评论
下载排行榜
