AD976/AD976A,pdf datasheet (Bi
消耗积分:5 | 格式:rar | 大小:570 | 2009-09-10
丁冬芹
分享资料个
The AD976/AD976A is a high speed, low power 16-bit A/D
converter that operates from a single 5 V supply. The part contains
a successive approximation, switched capacitor ADC, an
internal 2.5 V reference and a high speed parallel interface. The
ADC is factory calibrated to minimize all linearity errors. The
analog full-scale input is the standard industrial range of ±10 V.
The AD976/AD976A is comprehensively tested for ac parameters
such as SNR and THD, as well as the more traditional
parameters of offset, gain and linearity.
评论(0)
发评论
下载排行榜
