AD7376,pdf datasheet (128-Posi
消耗积分:2 | 格式:rar | 大小:514 | 2009-09-22
李静
分享资料个
The AD73761 is one of the few high voltage, high performance digital potentiometers2 on the market. This device can be used as a programmable resistor or resistor divider. The AD7376
performs the same electronic adjustment function as mechanical potentiometers, variable resistors, and trimmers with enhanced resolution, solid-state reliability, and programmability. With digital rather than manual control, the AD7376 provides layout flexibility and allows closed-loop dynamic controllability.
评论(0)
发评论
下载排行榜
