AD5290,pdf datasheet (Digital
消耗积分:3 | 格式:rar | 大小:517 | 2009-09-22
王敏
分享资料个
The AD5290 is one of the few high voltage, high performance, and compact digital potentiometers2, 3 in the market at present. This device can be used as a programmable resistor or resistor divider. The AD5290 performs the same electronic adjustment function as mechanical potentiometers, variable resistors, and trimmers, with enhanced resolution, solid-state reliability, and superior temperature stability.
评论(0)
发评论
下载排行榜
