ADG3257 ,pdf datasheet (V/5 V
消耗积分:5 | 格式:rar | 大小:550 | 2009-09-25
刘高
分享资料个
The ADG3257 is a CMOS bus switch comprised of four 2:1 multiplexers/demultiplexers with high impedance outputs. The device is manufactured on a CMOS process. This provides low power dissipation yet high switching speed and very low on resistance, allowing the inputs to be connected to the outputs without adding propagation delay or generating additional ground bounce noise.
评论(0)
发评论
下载排行榜
