pic16c711,pdf datasheet (8-bit
消耗积分:5 | 格式:rar | 大小:344 | 2009-09-26
张艳
分享资料个
The PIC16C71X is a family of low-cost, high-performance, CMOS, fully-static, 8-bit microcontrollers with integrated analog-to-digital (A/D) converters, in the PIC16CXX mid-range family.
All PIC16/17 microcontrollers employ an advanced
RISC architecture.The PIC16CXX microcontroller family
has enhanced core features, eight-level deep stack,
and multiple internal and external interrupt sources.
The separate instruction and data buses of the Harvard
architecture allow a 14-bit wide instruction word with
the separate 8-bit wide data. The two stage instruction
pipeline allows all instructions to execute in a single
cycle, except for program branches which require two
cycles. A total of 35 instructions (reduced instruction set) are available. Additionally, a large register set gives some of the architectural innovations used to achieve a very high performance.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
