LM26400Y,pdf datasheet (Dual 2
消耗积分:3 | 格式:rar | 大小:551 | 2009-10-06
张亮
分享资料个
The LM26400Y is a monolithic, two-output fixed frequency
PWM step-down DC/DC regulator in a 16-pin LLP or thermally
enhanced ETSSOP package. With a minimum number of external
components and internal loop compensation, the
LM26400Y is easy to use. The ability to drive 2A loads with
an internal 175mΩ NMOS switch using state-of-the-art 0.5μm
BiCMOS technology results in a high-power density design.
The world class control circuitry allows for an ON-time as low
as 40 ns, thus supporting high-frequency conversion over the
entire input range of 3V to 20V and down to an output voltage
of only 0.6V. The LM26400Y utilizes peak current-mode control
and internal compensation to provide high-performance
regulation over a wide range of line and load conditions.
Switching frequency is internally set to 500kHz, optimal for a
broad range of applications in terms of size versus thermal
tradeoffs. Given a non-synchronous architecture, efficiencies
above 90% are easy to achieve. External shutdown is included,
enabling separate turn-on and turn-off of the two channels.
Additional features include programmable soft-start
circuitry to reduce inrush current, pulse-by-pulse current limit
and frequency foldback, integrated bootstrap structure and
thermal shutdown.
评论(0)
发评论
下载排行榜
