LM193/LM293/LM393/LM2903pdf datasheet
消耗积分:10 | 格式:rar | 大小:555 | 2009-10-08
百灵千岛酱
分享资料个
The LM193 series consists of two independent precision
voltage comparators with an offset voltage specification as
low as 2.0 mV max for two comparators which were designed
specifically to operate from a single power supply
over a wide range of voltages. Operation from split power
supplies is also possible and the low power supply current
drain is independent of the magnitude of the power supply
voltage. These comparators also have a unique characteristic
in that the input common-mode voltage range includes
ground, even though operated from a single power supply
voltage.
评论(0)
发评论
下载排行榜
