LM4941,pdf datasheet (1.25 Wat
消耗积分:3 | 格式:rar | 大小:551 | 2009-10-09
分享资料个
The LM4941 is a fully differential audio power amplifier primarily
designed for demanding applications in mobile phones
and other portable communication device applications. It is
capable of delivering 1.25 watts of continuous average power
to a 8Ω load with less than 1% distortion (THD+N) from a
5VDC power supply. The LM4941 does not require output
coupling capacitors or bootstrap capacitors, and therefore is
ideally suited for mobile phone and other small form factor
applications where minimal PCB space is a primary requirement.
评论(0)
发评论
下载排行榜
