DS16EV5110,pdf datasheet Video
消耗积分:5 | 格式:rar | 大小:556 | 2009-10-12
李鸿洋
分享资料个
The DS16EV5110 is a multi-channel equalizer optimized for
video cable extension sink-side applications. It operates between
250Mbps and 2.25Gbps with common applications at
1.65Gbps and 2.25Gbps (per data channel). It contains three
Transition-Minimized Differential Signaling (TMDS) data
channels and one clock channel as commonly found in DVI
and HDMI cables. It provides compensation for skin-effect
and dielectric losses, a common phenomenon when transmitting
video on commercially available high definition video
cables.
评论(0)
发评论
下载排行榜
