DS90LV031A,pdf datasheet (3V L
消耗积分:3 | 格式:rar | 大小:558 | 2009-10-13
分享资料个
The DS90LV031A is a quad CMOS differential line driver designed
for applications requiring ultra low power dissipation
and high data rates. The device is designed to support data
rates in excess of 400 Mbps (200 MHz) utilizing Low Voltage
Differential Signaling (LVDS) technology.
The DS90LV031A accepts low voltage TTL/CMOS input levels
and translates them to low voltage (350 mV) differential
output signals. In addition the driver supports a TRI-STATE®
function that may be used to disable the output stage, disabling
the load current, and thus dropping the device to an
ultra low idle power state of 13 mW typical.
评论(0)
发评论
下载排行榜
