DS90CF383B,pdf datasheet (+3.3
消耗积分:3 | 格式:rar | 大小:551 | 2009-10-14
石玉兰
分享资料个
The DS90CF383B transmitter converts 28 bits of CMOS/TTL
data into four LVDS (Low Voltage Differential Signaling) data
streams. A phase-locked transmit clock is transmitted in
parallel with the data streams over a fifth LVDS link. Every
cycle of the transmit clock 28 bits of input data are sampled
and transmitted. At a transmit clock frequency of 65 MHz, 24
bits of RGB data and 3 bits of LCD timing and control data
(FPLINE, FPFRAME, DRDY) are transmitted at a rate of 455
Mbps per LVDS data channel. Using a 65 MHz clock, the
data throughput is 227 Mbytes/sec. The DS90CF383B is
fixed as a Falling edge strobe transmitter and will interoperate
with a Falling edge strobe Receiver (DS90CF386) without
any translation logic.
评论(0)
发评论
下载排行榜
