74LVC1G384 pdf datasheet
消耗积分:5 | 格式:rar | 大小:333 | 2008-07-14
靓仔峰
分享资料个
The 74LVC1G384 is a low-power, low-voltage, high-speed Si-gate CMOS device.
The 74LVC1G384 provides one single pole, single throw analog switch function. It has two input/output terminals (Y and Z) and an active LOW enable input pin (E). When pin E is HIGH, the analog switch is turned off.
Schmitt trigger action at the enable input makes the circuit tolerant of slower input
评论(0)
发评论
下载排行榜
