The 74LVC1G66 is a low-power, low-voltage Si-gate CMOS device.
The 74LVC1G66 provides one single pole, single-throw analog switch function. It has two input/output terminals (Yand Z) and an active HIGH enable input pin (E). When E is LOW, the analog switch is turned off.
Schmitt-trigger action at the enable input makes the circuit tolerant of slower input
