Protel Advanced PCB v2.8
消耗积分:0 | 格式:rar | 大小:4860KB | 2017-04-03
海能星科技
分享资料个
  This is Protel PCB 2.8, with crack.
  This was once Protel‘s best PCB program, with very few bugs, and much better than
  their notorious version 3.
  Typically of Protel, the startup screen says it is v2.5 but the Help--》About box
  says correctly that is in fact v2.8.
  Protel for Windows v2.x Dongle Crack.
  Basically there is a loop which initialises the array of modules
  which are enabled before testing the dongle. Normally it sets them
  all to 0 (they are disabled) but changing the initialisation
  value to 1 instantly enables all modules without access codes or
  a dongle.
  Search String:
  8B BE 7E FF
  C6 85 2E AA 00 《《 CHANGE 00 TO 01
  83 BE 7E FF 15
  Apply this crack after installing PFW but before running it.
  The PFW.EXE dated 11/95 (in Crack directory) is already patched with this crack. Just copy
  it into the install directory. Enjoy.
  Acknowledgement to Muppet/95.
评论(1)
发评论
h1654155968.6502 2018-08-13
0 回复 举报
非常好用 收起回复
下载排行榜
全部1条评论
