AP1521,pdf,datasheet (White LE
消耗积分:3 | 格式:rar | 大小:443 | 2009-10-19
名士流
分享资料个
The AP1521 is a step-up DC/DC converter
specifically designed to drive white LEDs with a
constant current. The device can drive two, three or
four LEDs in series from a Li-Ion cell. Series
connection of the LEDs provides identical LED
currents resulting in uniform brightness and
eliminates the need for ballast resistors. The
AP1521 switches at 1MHz that allows the use of
tiny external components. A low 300mV feedback
voltage minimizes power loss in the current setting
resistor for better efficiency.
评论(0)
发评论
下载排行榜
