Examples Using the DS3930 as Voltage References and Digital I/O
消耗积分:0 | 格式:pdf | 大小:0.21 MB | 2017-04-12
分享资料个
  Introduction
  The DS3930 contains six 256-position nonvolatile (NV) potentiometers (see Figure 1), which makes the DS3930 an ideal device for applications needing multiple voltage references. All six potentiometers share a common low side. The potentiometers are separated into two groups of three 50kΩ potentiometers in parallel. Each group of three shares a common high side. The potentiometer wiper voltage can vary between 0V and VHI in 256 steps, where VHI is the voltage on HI0-2 or HI3-5.
评论(0)
发评论
下载排行榜
