1. General description The TFA9810 is a two-channel power comparator for high-efficiency class D audio amplifier systems. It contains two full-bridge Bridge-Tied Load (BTL) power stages, drive logic, protection control logic and full differential input comparators. By using this power comparator a compact closed-loop self-oscillating digital amplifier system or open-loop system can be built. The TFA9810 does not require a heat sink and operates using an asymmetrical supply voltage. 2. Features n Stereo full-bridge power comparator for class D audio amplifier applications n No external heat sink required n Operating voltage range: asymmetrical from 8 V to 20 V n Thermally protected n Zero dead-time switching n Current-limiting (no audible interruptions)
