LM89,datasheet,pdf(Temperature
消耗积分:3 | 格式:rar | 大小:555 | 2009-10-20
分享资料个
The LM89 is an 11-bit digital temperature sensor with a
2-wire System Management Bus (SMBus) serial interface.
The LM89 accurately measures its own temperature as well
as the temperature of an external device, such as processor
thermal diode or diode-connected transistor such as the
2N3904. The temperature of any ASIC can be accurately
determined using the LM89 as long as a dedicated diode
(semiconductor junction) is available on the target die. The
LM89 remote sensor accuracy of ±0.75°C is factory trimmed
for the series resistance and 1.0021 typical non-ideality factor
of the Intel® Pentium™ 4 and the Mobile Pentium 4
Processor-M thermal diode. The LM89 has an Offset
register to allow measuring other diodes without
requiring continuous software management. Contact
to obtain the latest data for
new processors.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
