LM96080,datasheet,pdf(System H
消耗积分:3 | 格式:rar | 大小:551 | 2009-10-22
吴藩
分享资料个
LM96080, compatible to LM80, is a hardware monitor that
contains a 10-bit delta-sigma ADC capable of measuring 7
positive voltages and local temperature. The LM96080 also
measures the speed of two fans and includes other hardware
monitoring on an I2C® interface. The LM96080 includes a sequencer
that performs WATCHDOG window comparisons of
all measured values and its interrupt outputs become active
when any values exceed the programmed limits.
The LM96080 is especially suited to interface to both linear
and digital temperature sensors. The 2.5 mV LSb (least significant
bit) and 2.56 volt input range is ideal for accepting
inputs from a linear sensor such as the LM94022. The BTI is
used as an input from either digital or thermostat sensors such
as LM73, LM75, LM56, LM57, LM26, LM27, LM26LV, or other
LM96080.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
