LM80,datasheet,pdf(Serial Inte
消耗积分:5 | 格式:rar | 大小:552 | 2009-10-22
靓仔峰
分享资料个
The LM80 provides 7 positive voltage inputs, temperature
measurement, fan speed measurement, and hardware
monitoring on an I2C™ interface. The LM80 performs
WATCHDOG comparisons of all measured values and an
open-drain interrupt output becomes active when any values
exceed programmed limits. A Chassis Intrusion input is provided
to monitor and reset an external circuit designed to
latch a chassis intrusion event.
评论(0)
发评论
下载排行榜
