LM92,datasheet,pdf(Thermal Win
消耗积分:3 | 格式:rar | 大小:554 | 2009-10-22
479461
分享资料个
The LM92 is a digital temperature sensor and thermal window
comparator with an I2C™ Serial Bus interface and an
accuracy of ±0.33°C. The window-comparator architecture
of the LM92 eases the design of temperature control systems.
The open-drain Interrupt (INT) output becomes active
whenever temperature goes outside a programmable window,
while a separate Critical Temperature Alarm
(T_CRIT_A) output becomes active when the temperature
exceeds a programmable critical limit. The INT output can
operate in either a comparator or event mode, while the
T_CRIT_A output operates in comparator mode only.
评论(0)
发评论
下载排行榜
