ADM1185,datasheet,pdf(Quad Vol
消耗积分:3 | 格式:rar | 大小:556 | 2009-10-22
分享资料个
The ADM1185 is an integrated, 4-channel, voltage monitoring
and sequencing device. A 2.7 V to 5.5 V power supply is
required on the VCC pin to power the device. Four precision comparators monitor four voltage rails.
All comparators have a 0.6 V reference with a worst-case
accuracy of 0.8%. Resistor networks that are external to the VIN1, VIN2, VIN3, and VIN4 pins set the trip points for
the monitored supply rails.
评论(0)
发评论
下载排行榜
