ADG901/ADG902,pdf datasheet (1
消耗积分:5 | 格式:rar | 大小:551 | 2009-10-24
微风挽雨
分享资料个
The ADG901/ADG902 are wideband switches that use a CMOS process to provide high isolation and low insertion loss to 1 GHz. The ADG901 is an absorptive (matched) switch with 50 Ω terminated shunt legs, while the ADG902 is a reflective switch. These devices are designed such that the isolation is high over the dc to 1 GHz frequency range. They have on-board CMOS control logic, thus eliminating the need for external
评论(0)
发评论
下载排行榜
