# pxlba generated file
# pxlBA.txt : Extract file used to extract properties for
# back annotation using packagerxl. Refer to Allegro extract
# documentation for more details on the syntax of this file
# and the Extract program.
# The lines starting with # are comments.
# The default version of this file extracts the minimum number
# of properties necessary to ba changes to packaging.
# To extract additional properties the user must remove the
# comment character ‘#’ from the appropriate lines. Or
# add a line with the property name to the appropriate section.
# a2pxl looks for this file in the current working directory.
# If it is not found there, it looks for it
# in the hierarchy in the following location:
# 《installation dir》/tools/pcb/text/views
# Connection view. File: pinView.dat
LOGICAL_PIN
# These properties must not be removed, moved or modified.
# vvvvvvvvvvvvvvvvvvv
NET_NAME
REFDES
PIN_NUMBER
FUNC_LOGICAL_PATH
COMP_DEVICE_TYPE
FUNC_SCH_SIZE
FUNC_HAS_FIXED_SIZE
FUNC_DES
# Any other PIN properties to be back annotated show up here.
PIN_NET_SHORT
PIN_NO_SWAP_PIN
PIN_NO_PIN_ESCAPE
PIN_PIN_ESCAPE
PIN_PIN_SIGNAL_MODEL
PIN_NO_DRC
PIN_NO_SHAPE_CONNECT
END
