ADI官方布线技巧
消耗积分:3 | 格式:pdf | 大小:1165KB | 2017-05-05
kounan
分享资料个
ADI官方布线技巧
  The Art of PCB Design ‹Good PCB design is a discipline that takes years to master. ‹Reliable High-speed, mixed-signal designs require a great deal of theoretical knowledge and practical understanding to be done properly. ‹We’ll cover many important concepts at a high level today.
 ADI官方布线技巧
  ‹PCBs 101 ‹Good High-Speed PCB Design Practices z The Power of Power and Ground planes z Proper use of decoupling capacitors z The True Nature of Resistors and Capacitors in High-speed Designs z High-speed Signal Propagation - Wires or Transmission Lines? z Impedance Mismatches, Series and Parallel Termination z Managing EMI ‹Mixed Signal PCB Layout z Grounding Mixed Signal Data Acquisition System z Ground Plane in Mixed Signal Designs z Power Filtering & decoupling z Parasitic Consideration z Control Differential line impedance ‹ Small Signal Layout z Consider Track Resistor Loss z Proper grounding shielding cable z Minimize PCB Leakage by Guard Ring z Prevent PCB Heating Temperature Sensors
评论(0)
发评论
下载排行榜
