移动电源转换的数字域
权力的产生、分配和消费有很多方面,通常涉及到从一种形式到另一种形式的转换的多个阶段,每一阶段都表现出其唯一的转换和控制。转换的基本方法通常是最有效地实现通过切换源电压的方式,可以提供整流,升压或降压转换甚至反转。
开关的主要形式是脉冲宽度调制(PWM),它提供了一个高水平的控制输出波形/电压,因此,也可以提供最大的效率水平。实现PWM控制阶段的功率转换可以(已经)在模拟域中实现的,而这可能在特定的条件下提供一个可以接受的解决方案,它提供了一些灵活性和可解,未必能在宽范围的操作条件下提供高效的转换。出于这个原因,PWM转换阶段的控制,现在过渡到数字域,在这个新的范例的核心是微控制器(MCU)。它提供的能力,不仅增加灵活性的设计,但提高效率。当然,这是复杂的代价,那么制造商们在做什么来缓解这种转变呢?
Still analog
The good news, for analog designers, is that digital power conversion still involves a significant amount of analog technology; MOSFETs are still used to switch and direct power. The bad news, for those not familiar with MCUs, is that the PWM signals used to control those MOSFETs are now generated by an algorithm.
This could clearly cause some consternation for engineers not familiar with writing embedded code, however many of the leading manufacturers targeting this application space now provide software libraries intended to help designers in the first instance, such as theSwitched Mode Power Supply Control Library offered by Microchip; a library that has been optimized for the dsPIC33F and dsPIC33E family of Digital Signal Controllers.
