ADG728/ADG729,pdf datasheet (Serially-Controlled, Matrix Switches)
消耗积分:3 | 格式:rar | 大小:151 | 2009-10-30
路过秋天
分享资料个
The ADG728 and ADG729 are CMOS analog matrix switches with a serially controlled 2-wire interface. The ADG728 is an 8-channel matrix switch, while the ADG729 is a dual 4-channel matrix switch. On resistance is closely matched between switches and very flat over the full signal range. These parts can operate equally well as either multiplexers, demultiplexers or switch arrays and the input signal range extends to the supplies.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
