ADG708/ADG709,pdf datasheet (C
消耗积分:3 | 格式:rar | 大小:224 | 2009-10-30
李鸿
分享资料个
The ADG709 is a low voltage, CMOS analog multiplexer comprising four differential channels. The ADG709 switches one of four differential inputs to a common differential output as determined by the 2-bit binary address lines A0 and A1. An EN input is used to enable or disable the device. When disabled, all channels are switched OFF.
评论(0)
发评论
下载排行榜
