ADG706/ADG707,pdf datasheet (C
消耗积分:5 | 格式:rar | 大小:220 | 2009-10-30
分享资料个
The ADG706 is a low-voltage, CMOS analog multiplexer comprising 16 single. The ADG706 switches one of 16 inputs (S1-S16) to a common output, D, as determined by the 4-bit binary address lines A0, A1, A2, and A3. An EN input is used to enable or disable the device. When disabled, all channels are switched OFF.
评论(0)
发评论
下载排行榜
