The SSL2101 is a Switched Mode Power Supply (SMPS) controller IC that operates in
combination with a phase cut dimmer directly from rectified mains. It is designed to drive
LED devices. The device includes a high-voltage power switch and a circuit to allow
start-up directly from the rectified mains voltage. Furthermore the device includes
high-voltage circuitry to supply the phase cut dimmer.
