Semtech Power Supplies 101
消耗积分:0 | 格式:rar | 大小:0.31 MB | 2017-05-23
分享资料个
  在最基本的术语,降压稳压器需要一个输入电压,并将其转换为负载所需的较低电压。有两种主要类型的稳压器,线性和开关。线性稳压器的工作原理是通过吸收输入和输出之间的能量差,而开关稳压器的输入电压,然后平均斩波电压,以提供适当的输出电压。
  一个电压调节器,它被放置在接近设备或设备,它是供电通常被称为一个点的负载调节器。这种类型的稳压器经常收到从一个包含在PCB上的电压总线的输入。
  There are several parameters that should be considered when evaluating power supplies for particular applications.
  Quiescent Current – The amount of current an IC consumes when it is not source current and its inputs are not cycling.
  Efficiency – Defined as the ratio of power into a regulator circuit to the output power delivered by the regulator. Power input includes quiescent currents, losses due to parasitic components and power delivered to the load.
  Equivalent Series Resistance – The resistive component of the capacitors used in a regulator circuit. Attention needs to be paid to the ESR of the capacitors of the output.
  The Loop – Defined as all the elements affecting the output and stability of a regulator. This includes such blocks as the power stage, error amplifier, modulator, and compensation circuits.
评论(0)
发评论
下载排行榜
