锂离子电容器:一种有效的双电层电容器更换
一个公认的能源解决方案,传统的双电层电容器(EDLC)有许多明显的缺点与自放电特性、能量密度、可靠性、寿命和热设计。太阳诱电锂离子电容器克服这些问题和双电层电容器的一种有效的替代。锂离子电容器混合电容器,具有两个双电层电容器和锂离子二次电池的最佳特性(库)。
EDLCs是第一个在日本创造了在上世纪70年代,并于上世纪90年代开始在各种家电的出现。2000年以来,他们一直在使用手机和数码相机。双电层电容器通常用于防止突然的瞬间下降或中断供电。他们可以瞬间输出大量的电力,而电池不能。他们经常被用作备份电源的服务器和存储设备集成电路,处理器,内存和更多。
While EDLCs are intended to be backup power sources, conventional EDLCs suffer from a phenomenon known as self-discharge, where the capacitor will gradually lose its charge over time. Self-discharge can occur more rapidly during exposure to high temperature environments.
The extremely low self-discharge of a Lithium Ion Capacitor, even in high-heat environments, ensures a long-lasting charge.
Furthermore, Lithium Ion Capacitors have no risk of thermal runaway. No additional thermal design considerations, space or components are necessary when designing with a Lithium Ion Capacitor.
