74ls83 pdf datasheet
消耗积分:5 | 格式:rar | 大小:553 | 2008-07-17
李杰
分享资料个
4-BIT BINARY FULL ADDER
WITH FAST CARRY
The SN54 / 74LS83A is a high-speed 4-Bit binary Full Adder with internal
carry lookahead. It accepts two 4-bit binary words (A1–A4, B1–B4) and a
Carry Input (C0). It generates the binary Sum outputs R1–R4) and the Carry
Output (C4) from the most significant bit. The LS83A operates with either
active HIGH or active LOW operands (positive or negative logic). The
SN54/74LS283 is recommended for new designs since it is identical in
function with this device and features standard corner power pins.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
