What You Need to Know to Choose an Accelerometer
简单地说,加速器是一种机电装置,用来测量重力或运动随时间而引起的速度变化或加速度的变化。无论是传感方向和振动,还是检测到它附着的物体的运动速度,选择加速度计都需要考虑多种因素。
加速度计有着广泛的应用。当用于航空航天时,高灵敏度的加速度计被用作惯性导航系统部件。在工业环境中,他们经常检测和监测旋转机械的振动。我们日常生活中最熟悉的是我们的平板电脑、数码相机、游戏和智能手机,以确保屏幕图像处于直立状态。
那么,你怎么知道选择哪种加速度计呢?有很多问题要回答,从你的设计要求开始:
你需要模拟还是数字?
你需要单轴还是多轴?
挥杆水平是多少?
你需要高度敏感还是中档?
什么样的带宽?
你检查过阻抗和缓冲吗?
The choice between analog and digital is dictated by the hardware used. Analog accelerometers have an output that is a continuous voltage proportional to the acceleration. Digital accelerometers typically use pulse width modulation so that there is a square wave at a certain frequency. In this case, the time period of high voltage is proportional to the amount of acceleration.
The question becomes, what are you using in your design? A BASIC Stamp module from Parallax or a microcontroller with digital inputs will require a digital output accelerometer; when using a completely analog-based circuit, analog is usually the best choice.
