LAYOUT REPORT .............. 1
目錄.................. 1
1. PCB LAYOUT 術語解釋(TERMS)......... 2
2. Test Point : ATE 測試點供工廠ICT 測試治具使用............ 2
3. 基準點 (光學點) -for SMD:........... 4
4. 標記 (LABEL ING)......... 5
5. VIA HOLE PAD................. 5
6. PCB Layer 排列方式...... 5
7.零件佈置注意事項 (PLACEMENT NOTES)............... 5
8. PCB LAYOUT 設計............ 6
9. Transmission Line ( 傳輸線 )..... 8
10.General Guidelines – 跨Plane.. 8
11. General Guidelines – 繞線....... 9
12. General Guidelines – Damping Resistor. 10
13. General Guidelines - RJ45 to Transformer................. 10
14. Clock Routing Guideline........... 12
15. OSC & CRYSTAL Guideline........... 12
16. CPU
