额定功率只是一个电阻参数考虑
Phil Ebbert,工程副总裁,Riedon公司解释了为什么它是了解您的应用程序的系统要求能够欣赏今天的高性能电阻特性的关键重要。
电阻是电子元件世界的灰姑娘,从未像微处理器或其他数字或模拟集成电路那样迷人,甚至不像电容或电感器这样的无源器件那样神秘或有趣。因此,电阻器的性能要求常常被忽略,直到设计周期的后期,工程师才意识到他或她需要某种特殊的东西。可以理解的是,这是因为九倍的十,的要求是相当温和的,通常情况下,一个基本的碳成分(或同等)电阻,提供标准值10%的宽容和¼W的额定功率,符合要求的目的。
然而,由于碳组成电阻是正常的,新的技术,如碳膜、金属膜和厚膜现在无处不在,尤其是后者,现在大多数电路板需要表面贴装元件。
This is fine, but what if your application is more demanding? You may need a resistor that operates at more extreme temperatures (high or low), at high voltages or which provide closer, more precise tolerance values, and are stable over time, temperature, and other stress conditions. Other considerations might be high power dissipation, low inductance, and other environmental performance issues such as moisture resistance or avoiding outgassing in a vacuum.
By considering the advanced resistor technologies available from specialist supplier Riedon, this article will identify solutions that address these requirements.
