RDD104 pdf datasheet
消耗积分:5 | 格式:rar | 大小:666 | 2008-07-18
分享资料个
 DESCRIPTION OF OPERATION:
The  RDD104  is  a  CMOS  four  decade
divider  circuit  that  advances  on  each  negative
transition of the input clock pulse.  When the reset
input  is  high  the  circuit  is  cleared  to  zero.    The
clock  input  is  applied  to  a  three  stage  inverting
amplifier network  whose  output is  brought  out  so
that  an  external  crystal  network  can  be  used  to
form an oscillator circuit.  If the clock output is not
used,the  amplifier  acts  as  an  input  buffer.    Two
select inputs are provided which enables the circuit
to  divide  by  10,  100,  1,000  or  10,000.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
