The main oscillator allows either a crystal or single-ended input clock signal. Cost-sensitive
applications typically use an external crystal with the on-chip oscillator circuit since it is the mostcost-effective solution. It is also possible to use the internal oscillator to clock the device after theboot process has completed.
