LEDs Need Special Protection
消耗积分:0 | 格式:rar | 大小:0.07 MB | 2017-06-22
分享资料个
  高亮度发光二极管的出现为固态照明开辟了一个新的应用领域。除了更熟悉的使用,如家庭照明,零售场所的广告牌,展示照明,LED是目前常用的部署在汽车灯,路灯,应用交通信号灯、机场跑道标志。
  这些应用程序中的每一个都利用了LED的许多正面特性中的一个或多个。例如,与白炽灯相比,LED是耐振动和冲击;他们可以削减运营成本,降低电力消耗,减少更换和更新–寿命35000至50000小时的频率通常引用;他们是可靠的;而在电气特性方面,他们反应迅速。
  然而,为了获得这些相当大的优势,设计者确实需要意识到用led设计的一些潜在的缺陷。例如,它们比传统的由ESD引起的损坏和供电故障和雷击引起的电气瞬变的危险更高。这些事件在户外应用中比较常见。此外,生产HB组件最常用的技术,如使用蓝宝石或碳化硅衬底的技术,最容易受到这种损害。
  LEDs are also prone to the effects of temperature cycling and vibration, both of which can damage their internal wire bonds, leading to degradation and eventual ‘open failure’。 Over-current and over-temperature conditions can lead to thermal runaway-type phenomena. Nevertheless, even a fault that starts with an internal short, and the consequent heating, will most likely culminate, after failure of the internal wirebond connection, with an open circuit.
  At first sight, these somewhat unusual potential failure modes might seem little more than interesting oddities. However, there are some important consequences, particularly when designers choose – as they commonly do – to power a string of LEDs via a single constant-current power supply.
评论(0)
发评论
下载排行榜
