射频屏蔽:消除干扰的艺术和科学
在每一个无线系统中,几乎每一根线都成为天线或接收器,而它们无意中接收或传输的杂散信号会降低射频子系统的整体性能。良好的印刷电路板(PCB)设计和屏蔽技术可以大大减少电磁/射频干扰(EMI)和提供可靠的系统。本文将通过使用屏蔽和接地平面来防止杂散信号干扰无线系统操作,从而研究一些可用于最小化RF干扰的方法和现成产品。
电磁干扰基本上是由电路的一个部分发射出来的破坏性电磁能,通过传导或辐射路径到达电路或外部世界的其他部分。这种能量会对电路性能产生不利影响,甚至,如果足够高,也会对人脑细胞或其他器官造成损害。因此,任何RF设计的目标都是将发射的辐射减少到符合或低于任何规定的工业运行、安全和健康要求的水平。
In any of today’s wireless devices, EMI comes from two main sources – the RF front end that transmits the signal, and the internal digital circuits that often switch at Gigahertz and higher clock rates. Today’s designer must create a circuit board that has the lowest possible emitted radiation while operating at top speed to meet its performance goals.
Whether your design is a cell phone, a tablet, a portable computer, or some other portable product, good PCB layout is critical to keeping EMI to a minimum. Good use of ground planes and wiring layout that minimizes parasitic capacitance and ground loops goes a long way toward minimizing EMI.
